Hi all.
I'm repairing a faulty ICEPOWER ICE1000A audio amplifier (datasheet here
https://icepoweraudio.com/download/2408/)
It's a H bridge with IR2010 high and low side gate drivers, four FDP2532 mosfet (datasheet here
https://www.onsemi.com/pdf/datasheet/fdi2532-d.pdf) and a PNP bjt gate turn off:
" alt="" class="bbc_img" />
I've found one leg of the H bridge with high side mosfet completely destroyed (vaporized source and drain pins) and the low side mosfet shorted (gate, drain and source all tied toghether).
Since the FDP2532 is discontinued and not available from reputable distributors, I've replaced the broken two with an IPP075N15 (datasheet here
https://www.infineon.com/dgdl/Infineon-IPP075N15N3-DS-v02_06-en.pdf?fileId=db3a304319c6f18c0119cd76cc527ab6)
They should be approximately the same: lower Rds,ON for the replacement, and almost the same gate and miller charges. The same for the dynamic behaviour.
Unfortunately, the new mosfets heat up *a lot*, and a closer inspection revealed a crisp and cleart shoot through, in the range of 6 or 7 amps during turn on. This current is virtually no influenced by the bus voltage (why?). Increasing the turn on gate resistor from 12Ohms to 68Ohms completely eliminates the shoot through, but this results in poor distorsion.
In this image, top traces show gate voltage and drain current with original mosfets; bottom ones gate voltage and drain current of the replaced mosfet.
Same 12Ohm gate resistors.
[gate ringing is due to poor probe grounding; horizontal time is not consistent with the waveform: I'm showing off saved waveforms, this is what I get from a 20+ year scope]
No deadtime is inserted at gate driver input signals: the small deadtime comes from different turn on and turn off resistors.
Why I need almost a tenfold increase in gate resistor to avoid shoot through with almost identical mosfets?
What could I check?
