Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Hameg 103 oscilloscope
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Hameg 103 oscilloscope (Read 845 times)
gearheadgeek
Newbie
Country:
If its not broken still tear it apart
on:
October 21, 2019, 07:23:32 pm »
Hello EEVblog Im a long time reader and now a first time poster. I have acquired a Hameg 103 10 mhz scope and I cleaned it up and checking it over and went to calibrate the scope and probe and read the manual after downloaded it and by no means am i pro at this I just like to tinker and I run into a issue I have never seen before the instruction says to set the scope to 5 mv Y-AMPL and the timebase to 0.2 ms and should get about 4cm taken on the screen thats right but my traces are fat and when i press on the case they become normal. Im gong to try to include a video if i can. some help in the right direction would be most helpful
https://youtu.be/ZTfveKgK22w
I put a link to youtube I dont know if i can do this so please forgive in advance
Logged
james_s
Super Contributor
Country:
Re: Hameg 103 oscilloscope
Reply #1 on:
October 21, 2019, 07:54:59 pm »
I can't view the video, it says it's private.
If pressing on the case causes the trace to change then it sounds like you have a bad connection somewhere, I can't really tell you more without knowing more details.
Logged
gearheadgeek
Newbie
Country:
Reply #2 on:
October 21, 2019, 08:23:37 pm »
Hello james try it again I think i change my youtube correctly that was the very first video i uploaded i unchecked all the settings i think
Logged
shakalnokturn
Super Contributor
Country:
Reply #3 on:
October 21, 2019, 10:50:23 pm »
Looks like a weak contact somewhere on the focus adjustment.
Study schematic to get some idea of what components are involved, remove cover then try to figure-out which of those components get mechanical stress once you push down.
Also try prodding around with a dry chopstick.
Beware high voltage.
Logged
gearheadgeek
james_s
Super Contributor
Country:
Reply #4 on:
October 21, 2019, 11:16:18 pm »
I strongly suspect you've got a cracked solder joint in there and pressing on the case is flexing the PCB. You're gonna have to open it up and see what you can find.
Logged
gearheadgeek
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
