Author Topic: hameg 1503-7 security key  (Read 12299 times)
Offline rezapourkiaTopic starter
  • Country: ir
« on: January 09, 2024, 10:38:09 am »
Hi
I want to callibrate this oscop but when i want to factory reset oscop want "Press SeCURITY KEY!"
what i must do?
the main problem is i cant trim the Y axis  by potentiometer.
Thanks
Offline Chris56000
Re: hameg 1503-7 security key
« Reply #1 on: January 09, 2024, 02:09:33 pm »
Hi!
. . .It might be an internally fitted press–button on the microprocessor PCB that opens an additional Service Menu – you might find this oscilloscope does not use preset potentiometer adjustments, being software calibrated with the adjustments stored in EEPROM or non–volatile memory!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline Hamelec
Re: hameg 1507-3 security key
« Reply #2 on: January 10, 2024, 08:53:54 am »
you should correct the title to HAMEG type 1507-3, maybe then anybody can help you
« Last Edit: January 10, 2024, 07:50:47 pm by Hamelec »
