I have just bought an old (but nice) oscilloscope, a Hameg HM203. Next to me, all the functionality that should be there, is there. Besides that the scope needs some calibration, I wonder whether the next phenomenon could also be adressed during this adjustment (calibration):
When connecting a probe to the 200 mVpp square wave output eyelet, a square wave is shown. But, the positive horizontal line segments of the square-wave are significantly longer than the negative ones. This happens on both channels. I've included a photo of the result following the standard instructions for viewing the standard square-wave signal in the manual, and also a version with a time-base that shows the difference more pronounced.
With difficulty I found a hard to read copy of the adjusting plan. (It is a pity that I did not find a step-by-step calibration procedure, by the way..) Most text labels next to the adjustment pots are kind of self-explicable, but neither of them indicates or suggests (to me)that it will address the asymmetry in the signal projection.
Can one of you help me with this problem (if there is one..? :-)
