Author Topic: Yihua 3010d-iii bench power supply "SCP" error  (Read 1233 times)
Offline jetuaime81Topic starter
  • Country: in
« on: February 29, 2024, 04:05:34 pm »
I bought a yihua 3010d- iii psu. The problem is I am not able to inject voltage and heat components; as soon as short is detected, SCP error comes up (short circuit protection). I tried in many voltage and current settings but shorting gives SCP. CC works properly when a load is connected but that is not why I purchased this. The seller isn't agreeing to replace or refund. The video below clearly shows it should not give SCP when shorted; pardon me it's in Indian language. Is there anyway to disable SCP on this board? Or maybe a work around? My requirement is to check shorts on motherboards so I will need to inject as low as 1V.
https://youtu.be/uGIf2_m2sPw?feature=shared&start=265
« Last Edit: February 29, 2024, 04:11:56 pm by jetuaime81 »
