I have recently acquired an old hameg 303 - 5 in what looked liked perfect condition. After two days of use,
the trace was no longer visible on the whole screen. Rather it seems to start a bit to the left of the center,
with a bright dot at the beginning of the trace. If i tune the x position, the whole trace doesn't move further to the left, it only shrinks or stretches. It doesnt however stretch or shrink linearly like when using the time/div button. Rather it appears to shrink/stretch more in some parts of the axis than others. The y axis
is working perfectly across the whole height?
If any of you were to have an idea about what the issue would be it would be very welcome, for i need to
use this oscilloscope on a daily basis and all of my work is completely haltet without it.
Thank you very much for any answer!
