A friend of my same age likes to say he is not "old"; he is "semi-young".
That scope has given me good service all these years and it is the first time it has given me any problem and, as you can see, it was easy enough to fix. The amount of dust I found inside... that is something else. I am surprised any switches still work.
The metal case is 40 cm (16") long and it sticks out a bit on the shelf. In its time it was "portable" in that I would use it by the car or motorcycle. I fitted some rubber pads/legs in the back and I could stand it vertically on the ground with the screen facing upwards.
I had never really looked at the schematic until now (it is good that I am very meticulous about keeping documentation) and I find it interesting to note the first stage has a differential input but one side is put to ground. It makes me think it might be relatively easy to make it truly differential although probably not worth the trouble.
