Hello,
Instability of the X-Sweep (moved 1 cm) adjusted by changing the entire THT regularization chain. (Transistor BF459, CI LM741, and resistance test).
However, there is still a problem to solve, we see the trace return. (No extinction of the spot).
Strange if I put a new opto CNY17-1 instead of the CNY17-2, no trace. The components are practically identical on the datasheet.
I’ll dig this circuitry, some resistors, two transistors and diodes.
An idea for measuring THT without a probe?
see documentation and schematic on PJ
cdt
