Hello,
I bought a "working" Power Supply a few weeks ago. It was not....ok.
I agreed with the seller on some return money because I think it is a good Power supply and worth a repair.
So after I bought it, my money box is mostly empty in the moment, and R&S ask for a hand and a limb in repair.
I decided I will try to repair it and if I can't fix -> R&S must do it.
First all looks ok and working, it start´s without an Error, I can set the Parameters local and remote.
But, when I enable the Output, Cannel 1 and 3 there is no regulation, Volts goes to some other Values and Amps are not there.
So it looks something is broken.
Because im lacking a Service Manual I can only guessing what is broken.
So I Inspected the Circuit and found something suspicious, one chip looks like it was loosing his smoke.
Can someone Identify this ic ?
Here the Smoky one
Here the other one from Channel 1.
A few pics from the Board´s because I know, someone like to see the whole thing.
Thanks a lot for your time and help.
Stefan
