Ok boys ,
good news first
here is some pohotos after litle callibration process.
generator signal from owon
The same signal from hameg
Front panel cleaned and completed
And now somethink bad
Chanell B was broken input FET transistors and I used BF245B. Also T204 was bad and replaced by same type.
But now is aplitude on the screen from channel B about 10x lower as on channel A.
Is possible change some pasive or is needed to change FET?
Better replacement of TIS69 I think like 2N5199, 2N5046, BFS21A.
Or can be something other wrong? Signal after attenuator is the same as from channel A.
