Author Topic: Hameg HM1507-2 repiar  (Read 2060 times)
Offline jackie.cenTopic starter
  • Country: cn
« on: October 26, 2018, 07:07:17 am »
hi there,
i got a hameg hm1507-2 scope.it did not display anything.so i repair it.it did not have the HV voltage.i change the voltage multiplier,it made by myself.
so it displayed.but the screen did not display the whole image ,only about 1/4 image.
i change the all of the potentiometers,it did not work as expect.does someone have the schematics for this model?
Best regards,
jackie
  • Country: cn
Re: Hameg HM1507-2 repiar
« Reply #1 on: October 26, 2018, 07:13:13 am »
the Follow
  • Country: cn
« Reply #2 on: October 26, 2018, 07:14:47 am »
the follow
Offline ElecSeb
« Last Edit: October 26, 2018, 07:18:07 am by ElecSeb »
  • Country: cn
« Reply #4 on: October 28, 2018, 01:22:03 am »
thank you!
i fix it,now it's ok!
  • Country: cn
« Reply #5 on: October 28, 2018, 01:35:26 am »
first i find the voltage multiplier is dead,so i made one by hand.it's about 85:8:800,65v 75% square singal input.
  • Country: cn
« Reply #6 on: October 28, 2018, 01:39:09 am »
after the new voltage multiplier,the screen is still blank.i change the resistances,the screen is work,but image is out of the screen.
  • Country: cn
« Reply #7 on: October 28, 2018, 01:47:41 am »
the image is bigger than screen,because the amplitude of x and y singal is big.my plan is reduce the amplitude of x and y singal.change 3 resistances ,about half of them.
  • Country: cn
« Reply #8 on: October 28, 2018, 01:51:19 am »
now the image is ok,but image is not clean,the text can't read.change the potentiometer and focus on the front panel.it would be ok.
Offline carlitos
  • Country: pt
« Reply #9 on: June 09, 2020, 10:19:26 pm »
sorry bother you, but I have same oscilloscope and I am repairing it.
Unfortunately the high voltage transformer was lost in transportation to a rewind shop to repair it.
Is it possible to send some details how you rewind this transformer, like how many turns, wire diameter, wire orientation and pinout connection.
Thanks a lot.
Best regards,
Carlos
