I successfully dismantled and cleaned the rotary encoder.(finally
) I reassembled the unit it passes self tests but the trace is nowhere to be seen. Although there is a glow at the top of the screen on high intensity settings as there is when the trace has gone off screen. Auto set and vertical position are no help though.
The canned board with the b&cs had to be disconnected and I haven't tried re plugging the ribbons yet.
The cal sticker was right alright. Its definitely void
TIA
