Where did you find one here in the US for that price? That's better than I've seen anywhere. Or did you go Alibaba or something? I find it hard to locate Hantek product here in the US, since it's mostly eBay sellers (in China) offering it. That model is on Amazon... for about 650 bucks.
AliExpress, 15% off sale... Beware that these are probably not UL listed. Most of us here probably know this. I don't plan on using this device until I survey it's power supply circuitry and the quality of vital passive components.
a) the memory depth on this is 1M samples/channel. That's really not bad at all, though the Rigol you mentioned has 6x that.
There is a new recent picture floating around of a actual MSO5074F with a 2M memory depth. My fingers are crossed that I get that one, but who knows...
b) it doesn't look like there are any protocol decode capabilities (that I could see)
I hope there is, but obviously it is only a software limitation if so. Since it is new, I have no doubt that there will be firmware or software updates to fix that. If not, I have my USB logic analyser for decoding via laptop. How much can you really expect to get out of a $500 scope?
c) the "logic" inputs are spec'ed to a maxInput of 3V. That makes no sense to me at all.
I saw that and plan on testing and looking at the logic input. Nothing so terrible that some zeners can't solve. I'm hoping it is 5V safe, but I will post info to let others know.
d) I have no idea about this unit, but previous Hantek's had no SCPI capability. That can be a real disadvantage, for some folks.
There are community developed tools for Hantek's USB/LAN protocol that is documented. I plan on updating the software to take advantage of the 4-channel analog (and the logic and AWG if possible). The Hantek supplied tools are known to be quite limited. I have been a software programmer for over 15 years and have plans to update the community software if there is enough interest.
http://elinux.org/Das_Oszi_Protocolhttp://peter.dreisiebner.at/dso-usb-tool/Oh, and one additional comment on the Hantek MSO5074FG. I knew this was fairly "new", but I didn't know it was "brand new". Aka, I thought it had been out a while, but apparently not.
I believe Hantek announces some products early. The MSO5074 looks like it was released late last year (
http://www.hantek.org/asken/iaskdetail.aspx?id=2013072518442475). I never said it was brand new. Maybe just for US dealers...
Checking out the Hantek site for more information, I see there is NO User Manual available. And no Programming Guide. AND not even a Data Sheet. Just some info in a table on one tab... which leaves out a lot of information.
True. I thought this through a lot before I decided to take the chance and buy it. I think it is worth the risk for me.
User Manual is floating around somewhere. I have seen a scan. I know it is included, I don't know which language
The lack of documentation is a problem for long term use, and if you intend on doing self-repairs. The community on this site helped me overlook this issue, as it seems that the community support is great and has some very skilled active members.
Sounds like you should have some fun checking this out.
I sure am!
