Excuse me for my absence, i was bored about the scope and totally forgot that i posted this
-using the calibration pins on the oscilloscope (square signal of 2v) i can make the vacuum tube display the voltage but not the time (sorry, i couldn't use sin wave sadly my frequency
generator is broken too)
-using both channels with the x-y button makes a sideways line with the square signal of 2v (see in the picture)
-since the timebase is not working and it could be the contact fault on the time base knob, what can i use to clean it ?
-the trig does not light up so it may be due to the poor contact or an other problem
checking directly on an other oscilloscope is not necessary, just responding to my questions is enough, you are already wasting too much time for me
Thanks to all of you for responding to my questions, i greatly appreciate it
