Hi all - first post....
I have a HAMEG HM605 which I got slightly broken a few years ago which I bodged a fix to the output transistors on the trigger board. There were dry joints I could not access very well. I did some blind soldering and used a jumper wire on the top surface. This evening I thought I would fix properly, so I removed the top trigger board to access the underside and solder joints. It involved removing all the rods attached to the board and desoldering 2 wires, one yellow one labeled ZUP on the schematic and one orange one at the front which just connects to the external trigger. There were 2 ribon clips to remove as well. With the board able to be flipped over I went over all the joints by the 4 output transistors to CRT and any dry joints in that area, mainly the resistors adjacent to the transistors.
Reassembled, and turned on. Nothing on the screen - no flat line for either channel. Hooking up channel one to the inbuilt signal generator, I get the square wave, but it takes fairly precise adjustment of the trigger level, with a small window. When I add channel 2 I get the flat line for channel 2, but when I pull the probe from channel 1 out of the signal generator, both traces disappear.
For some reason I get nothing on the CRT unless a signal triggers, and channel 2 only works when channel one has triggered.
The area I was soldering in works ok, so I have not screwed anything up there, but for some reason I only get a trace when channel 1 triggers. I have the schematic, but don't quite know where to start regarding working out where the fault is I have introduced
I gave the Y-Board a gentle clean of dust with a soft brush on the solder pin side, as I could see it with the TB lifted.
I am happy to give further details or try different things if that would help drill down to the problem area.
