Author Topic: Hameg HMO352x HMO3522  (Read 2115 times)
Offline ino5onTopic starter
« on: June 30, 2016, 08:16:18 am »
Hello to all
My Hameg HMO3522 did shut down while doing nothing and won't turn on again.  :(
Does anyone has the schematic / service manual ?
Thanks for your help.
Online kripton2035
Re: Hameg HMO352x HMO3522
« Reply #1 on: June 30, 2016, 10:27:03 am »
you can ask the hameg support on their web site - they are very helpful.
isn't it still under warranty ?
« Reply #2 on: June 30, 2016, 10:33:31 am »
no more warranty :-\ and rode & schwarz won't send me the service manual, I should send it in. But why spend a lot of money, if I could fix it my self.
Offline nctnico
« Reply #3 on: June 30, 2016, 11:14:31 am »
You could check the fuses and the power supply IF you have experience with repairing these kind of circuits.
« Reply #4 on: June 30, 2016, 11:28:06 am »
I can measure the voltage behind the rectifier (german Gleichrichter) but there is no more voltage at the transformer (german Übertrager)
Online kripton2035
« Reply #5 on: June 30, 2016, 11:43:25 am »
http://www.repairfaq.org/sam/smpsfaq.htm#smpssfmod
don't forget to read the safety measures before ...
« Reply #6 on: June 30, 2016, 11:56:24 am »
I got an FI Switch ;)
Just kidding
It seems I have a lot to read
Offline nctnico
« Reply #7 on: June 30, 2016, 07:22:58 pm »
If you have the SMSP removed from the scope perhaps you could make some high-res pictures and post them somewhere with a link here. What often helps is to identify the switcher chip used and then look for a datasheet or even better an application note with a circuit which closely matches the PSU at hand. The datasheet is likely to also help to give a detailed description of the chip and how the circuit works.
There are many checks you can do before actually applying mains voltage to the PSU with all the asociated dangers.
« Last Edit: June 30, 2016, 07:27:30 pm by nctnico »
Online kripton2035
« Reply #8 on: July 01, 2016, 05:59:18 am »
Just kidding
fixing smps is quite easy in the long run (but lot of the time is it worth fixing or replacing ?)
but I've never been able to fix smps with PFC that are far more difficult to understand.
