Hi! Playing around with my "new" oscilloscope Hameg HM 512 I found an issue regarding XY-Mode: It doesn't show anything, not even a dot somwhere in the middle without a signal. Only sometimes while pushing the button there's a dot in the middle for a very short (1/10 second) time.
Channel 1 and 2 work just fine. Also measuring voltages on test spots on the boards (+/- 12V, 5V, ...) hasn't shown obvious issues. I cleaned the "Hor ext" switch on the X-board with some alcohol but no change.
Does anyone have a hint for me where/what to look for? Thanks
P.S.: As manual/schematic is too large for upload here the link:
https://www.sky-messtechnik.de/images/PDFs/HM512-6.pdfUPDATE: For whatever reason the timebase has stopped working. I have only a vertical line for both channels. No change about the X-Y-mode though.
