Greetings! I have an old 22-inch HannsG that has worked faithfully as a security screen for years. (On 24/7 365)
Couple days ago it started to come on for 3-5 second and then the backlight would go out, I could still see a picture if I illuminated the screen with a LED flashlight.
I pulled it apart and changed the two caps that looked suspect the others visually looked fine. No change, power on 3-5 secs and the backlight would turn off
Being a newbie in electronics repair, is it possible for a capacitor to fail internally and show no outward signs?
Thanks!
