Having a diddly of a noodle baker trying to mend this thing.
The symptoms are that the power supply cycles every second. The rails come up and are stable then it cycles and starts again.
I am making the following assumptions based on the schematic that I downloaded from here.
1) There is no feedback from the main scope board to the PSU
2) Only the five volt output from the power supply is monitored and fed back through the opto to the chopper on the mains side.
The scope was like this when I got it (ebay purchase). The guy I got it off had tried to sort it. Checked soldering and replaced the main chopper IC/transistor.
I have checked all the components and they all seem fine. I have changed the TL431 and the opto isolator. The appearance is as new, no dust or grime anywhere, the scope has clearly not been used over much at all, possibly never.
My power supply differs slightly from the one on this forum and this is (as far as I can work out) the difference.
R13 and R14 are getting hot, > 50c and this is without the supply plugged into the scope, just sitting powered form mains. I have run it from a variac and it does the same down to 90volts when it stops working, sort of what one would expect.
The circuit seems not sensible to me. I have fed varying voltage volts into the five volt rail and the opto does work, at some point it goes short on the mains side.
Stuck now, suggestions please.
