Hi Grumpydoc, your French is quite perfect
I have replaced the ADG321D ASIC with one new from aliexpress.
I have no more noise on channel 1 but I still have the message "CH1 and CH2 aquisition failled" on startup.
Probe comp is still 3 kHz? I have tried to reverse engineer the PCB, and the probe comp signal is comming from the other ASIC ADG422.
I think my problem are caused by an early stopped calibration process.
I need to find the right equipement to perform the factory calibration.
