Hello everyone!
I finally received a HP5385A counter from an eBay seller located in Israel, I believe these were used by some military unit. The counter was described as “perfectly working” and the price was right, about 100 $ - although it actually more than doubled with postage and custom taxes by the time it reached me.
However, the counter has a hard time reading low level signals, so I tried to look for the problem, and I found a rather sloppily made repair on th board. R2, a 51.1 Ohm 1% resistor, that from the diagram I imagine being the internal terminator, somehow burned and was replaced with a part that I am not very familiar with a Vishay RLR/C military metal film resistor of the correct value, see images. The two resistors (R3 and R1) at its sides are badly scorched as is a small capacitor (C1), which have been left on the board. Also, lots of black flux caked on the board. There’s also signs of an IC replaced, U6, a Harris 1858 (wonder what that is).
So my question is:
The problem I see reading a frequency below the 3-4V level, can it be caused by this resistor?
Should I replace the two resistors around R2 and the capacitor?
Can the black flux burned frp! cause a problem?
There are other things, but those I can cope with, like a broken off rear BNC for the ref input.
Edited to modify after some research.
Thank you guys!
