I recently got a Hart Scientifiy (now Fluke) 1522 digital thermometer, which is not fully operating. First of, an SMD coil was flying arround in the case (core broke off from its support, and was only held by one of its two wires); easy fix, used some epoxy glue to reseat the core and soldered the broken-off wire.
Secondly, the NiMh battery is missing. Does anybody know what type is used there (seems a three cell battery, from the pictures I have seen, but voltage unknown). The manual does not say anything and the original spare part is unobtainium.
Thirdly, it needs calibration (it says so on its display). For this, one needs to enter a passcode which is shipped on a tag together with the meter. Of course, it did not come with my used meter. In such case, one is supposed to contact the factory. I have not done that yet, and being in Germany, am not sure the Netherland Fluke support will help, so before I contact them, maybe someone here knows just off of its head (if it is that eays, e.g. the HP 3458A DMM uses 3458
And finally, anybody knows the pinout of the 6-pin cardedge info-co connector? Precision resistors are needed to do the cal, should be easy with known pinout, and I would prefer to get some data, if there is (have not found anything), rather then measuring, so link or just info would be nice if someone has.
