Author Topic: Has anyone disassembled an IR189USB fluke cable?  (Read 202 times)
Offline rauldm
  • Country: mx
« on: December 02, 2019, 02:41:03 am »
I bought a Fluke 289 FVF kit, but the USB came with problem, I return my kit to store, they sent me a new kit, again same problem, only works with IR3000FC, finally I discovery, if I put the connector with 5 mm clearance between meter, it works, I put a dark plastic film inside the connector on IR LED and works too, I showed this to Fluke, they sent me new USB cable and it works finally. I think if I unassembly the connector and change the IR LED resistor it can works normally, but I don't want  damage the connector case.
Regards.
Offline coromonadalix
Re: Has anyone disassembled an IR189USB fluke cable?
« Reply #1 on: December 02, 2019, 02:51:51 am »
theres was a thread here
https://www.eevblog.com/forum/buysellwanted/w-t-b-fluke-ir189-usb-usb-cable-280180-series/msg1436629/#msg1436629
The third post  if i recall
There was an clone still sold on ebay
https://www.ebay.com/itm/USB-optoisolated-IR-adapter-for-Fluke/182450421884
Some googlefuu will show you schematics
But for the transmission problems  i think thre was an issue with the comparator used vs the voltages references, something like this ???
For dismantling the case, i would use an brand new xacto blade and slowly make a way between the 2 case parts
« Last Edit: December 02, 2019, 02:56:18 am by coromonadalix »
