A little update, it appears the SME and SMT series generators use the same feet, so if you've got one of those and want to help, that would do nicely!
Gotta do a test print, but I think I've got a good copy of the encoder wheel (uses a 6mm round shaft) in all plastic (original is a split tube with a metal ring for reinforcement).
