No I used new TIM on it right after the 1st time I tried it. It's not anything mechanical.
To me, it actually looks like there's 3 area's of the PCB that are dis-colored. They are right around the GPU die, but closer to the VRAM than the GPU die. Didn't seem to wash off with rubbing alcohol.
When multilayer PCBs get a bit cooked inside, can they get discolored on the surface ?
I really want to measure the current to it, I should wire up an adapter and measure what the PCI-e cables are delivering.
As for testing these out of circuit, I'm wondering what all logic signals are supposed to be present for them to even turn on, when not connected to a mobo. I should try anyways. 1st I need to make sure the fan will work directly off 12V w/o PWM, and then I wonder if the GPU will work if the fan is not detected.
I know chips will die in seconds without a heatsink. When it shuts down, the backplate that holds the heatsink, is almost 2 hot to touch. Something has to be drawing way too much current.
