The opamp is not part of the oscillator. The transistor is in a blocking oscillator circuit with positive feedback from the 1.45 ohm winding to its base. The opamp adjusts the dc voltage at the transistor base and that changes the on/off time ratio.
You may find that it will not oscillate when powered from only 3 Volts.
Ensure the replacement resistor is rated for more than the voltage across it. If the four are all 1.5 Mohm, then about 500 Volts across each.
thank you. You were right. Here is a picture of the chopping on the Collector of the transistor
The Good news,
i was able to repair the HV section, now all of the voltages, +12, - 12, 5, 145 and 2Kv are correct!
the bad news:
-at first, no trace, not even a dot on screen. I measured transistors and diodes on the Vertical and Horizontal Final Amp. LOTS OF DEAD TRANSISTORS
(15 more or less), also all the logic
ICs do not work, i haved to take it from the sockets, then make a circuit on the protoboard just to test them (
74LS74, CD4011, 74S00), i guess they broke because of the HV arcs and flashings. I replaced all of this faulty components.
Now i just have a dot, it moves with the
horizontal position potentiometer, it
does Not move anything at all with
the vertical position pot, but the dot is in the middle of the Y axis, so i guess the vertical final amp its ok (if not, it would be a little more up or down in the y axis right?
I tested the vertical attenuators, on both channels, by removing the pcb, they seem OK. The sweep generator is in this pcb too
, its single opamp is completaly dead, i replace it, but i dont know how to test this sweep section to confirm tha now all is ok
ok, so now here are my problems:
i dont know how to test or debug the Sweep generator and the trigger circuit
, i dont know how it works and if i make measurments of the Q or Q̅ pins i will not know what it would mean
(if anyone can give tips on this i would apreciate it a lot, i dont even now how to google on this with out lost my self)
i guess i need to test the vertical preamp (because the attenuators are ok) and confirm that the Final Vertical Amp its ok too. how i do this without risking the circuit and my other scope(the one im using to make the measurments)?? i have to use x10 probe in orther to not affect the Device under test?
