Author Topic: unknown DC-DC chip of SI-9110 differential probe  (Read 2616 times)
Offline teatimeTopic starter
  • Country: cn
« on: April 19, 2024, 09:00:43 am »
Hello all,
Right now I have a defective SI-9110 differential probe,
Input 6Vdc,
the problem is no -12V, +12V is normal.
I checked the waveform of Pin15, the PWM of +12v as  attachement.
But Pin 10 no any waveform.
If using external -12v instead, this differential probe works properly.
So the only problem is the DC-DC chip.
But the factory erase all chip mark.
I have draw the schematic of this part,please see the attachement.
The length of this chip is 1cm.
The bottom marked"NBK" and have a "Philippines" mark.
I hope some one can tell me the model of this chip.
Maybe this chip also used on other type differential probe.
Thanks & Best regards
Offline BennoG
Re: unknown DC-DC chip of SI-9110 differential probe
« Reply #1 on: April 19, 2024, 11:02:44 am »
I don't see any feedback divider, so this chip is specifically designed to generate +12V and -12V.
But I can not find that kind of boost converter controller.
Benno
Online coromonadalix
« Reply #2 on: April 19, 2024, 02:46:19 pm »
but feedback pins are 9 and 16 for the ic  ??
if the schematic is ok ?
Offline BreakingOhmsLaw
  • Certified solder fume addict
The following users thanked this post: fzabkar, teatime
Offline asis
  • Country: ru
« Reply #5 on: April 19, 2024, 07:43:33 pm »
Here is part of the diagram of the working product.
The following users thanked this post: teatime
  • Country: cn
« Reply #6 on: April 20, 2024, 01:05:16 am »
After compare with the datesheet, MAX743 is the right chip.
Thanks alot for your great help!
The following users thanked this post: BreakingOhmsLaw
  • Country: cn
« Reply #7 on: April 20, 2024, 01:08:06 am »
After remove the chip, then I draw this schematic, it's right.
The chip MAX743 is the chip I needed.
