I like Heathkit stuff, reminds me of the times when you could just walk into your local electronics retailer and walk out the door with a brown box with the heathkit logo and a lot of parts inside to put together and end up with something usefull that you build yourself plus the fun doing it. Another sleepless night... So I like once in a while get something Heathkit off ebay to restore and put on the shelf for eventual use, and the IG-1271 had been on my to get list for a while.
Actually got the SG-1271 version, so this was factory wired, not a kit. No problems with this unit, so just wanted to do the cal procedure to make sure everything is on spec. First step is to do the Lo/Hi dial calibration on the 1K frequency range, which basically entails carefully adjusting both the Low Freq Dial adjust and Symmetry adjustment trimmers to get an even 100Hz triangle wave output at 0.1 dial position, plus set the offset trimmer for even +/- waveform defection, CHECK. Then rotate dial to 10 position and calibrate High Freq Dial adjust trimmer for a 10KHz output, CHECK. And finally set dial back to 1.0 position (where before any further adjustment I'm now reading 833Hz output at this point) and readjust Low Freq Dial adjust trimmer for 1KHz, CHECK. Everything dandy so far, but now when I go to check the frequency output at the 0.1 dial position I do get 225Hz, instead of the expected 100Hz. At this point I am still getting 1KHz at the 1.0 position, and 10KHz at the 10 position, but apparently there is no way to get 100Hz at the 0.1 dial position without disturbing the calibration of the 1.0 position. I've done the calibration steps several times over as indicated in the manual, but always arrive at the same result: 225Hz at the 0.1 dial position, while 1.0 and 10 are still correct. And if I set the 0.1 dial position to be back to 100Hz, the 1.0 position will read 833Hz instead of the expected 1KHz. The 10 position on the dial will still be accurate at 10KHz output as this is set with a separate trimmer adjustment.
Now given that Heathkit has not always exactly been high on accuracy or design perfection (at least not anywhere near a la HP, Tek, etc), I wonder if this error on the 0.1 dial position was considered a "normal", or if there might be an actual still undiscovered problem in this unit, or maybe an error in the write up of the calibration procedure? I've also checked voltages around the main variable oscillator circuit and everything agrees to what is shown in the diagram. Even checked resistance and tracking of the R103 dial pot which is 1K LIN, and to the best of my capabilities it seems to be tracking fine. Function-wise everything else seems to be working fine in the generator, besides the 0.1 dial position frequency error.
So what gives? Before I start what might turn out to be a wild goose chase, anyone out there with an IG-1271, could you please check your output frequency at the 0.1, 1.0 and 10 dial positions (at the 1K frequency range) and report back your findings? Or if anyone have any ideas or suggestions, or maybe also ran into the same calibration problem, I'd appreciate any input.
BTW, since I saw quite a bit of spikes on the +/-15V rails, decided to replace all the 10uF 20V Tantalum caps (seven in total) with fresh 10uF 35V units, but it did not help much to quiet down those rails. Switching spikes exactly correspond to highest and lowest part of sine and triangle waveforms, and rising and falling edges if compared with the square wave output. So I guess these spikes are also part of the original design as well. The main +/- 28V rails looked clean, and the main filter caps still look good, no bulging or any visible defects, so left them alone.
I also noticed both power supply pass regulators (one voltage regulator and a transistor) get extremely hot and are set horizontally against the board with absolutely no heat sinking. I modified both pass devices to be vertical and attached an individual heatsink to each one. They still get hot but at least now the heat is being taken out of the devices to some extent. Same goes for the two main output transistors, which are TO-202 tab devices, they get very hot due to no heat dissipation aid, so I modified two TO-220 heat sinks (new hole) and attached them individually to avoid having to use insulators, as the transistor tabs are each respectively at plus and minus 28V coming straight from the main rails.
Thanks in advance for any input.
