Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Repairing SL-1730SL20A Power supply. What is this component
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Repairing SL-1730SL20A Power supply. What is this component (Read 2203 times)
JacquesBBB
Frequent Contributor
Country:
on:
June 05, 2017, 09:00:29 pm »
Dear All,
I am trying to repair a linear 0-30V - 0-20A Power supply (SL-1730SL20A). The design is very similar
to the more classical 0-30V - 0-3A,
https://www.eevblog.com/forum/repair/tracking-problem-in-a-dual-bench-power-supply/msg529140/#msg529140
but with a much larger transformer and a single canal.
I suspect now that the problem comes from some shutdown feature, and came over this component which
I cannot identify. Quite surprisingly, it was connected only on one side, and the wire on the other side was cut.
Is this a thermal sensor ? If yes, what should be its resistor ? Thanks !
Logged
JacquesBBB
Country:
Re: Repairing SL-1730SL20A Power supply. What is this component
Reply #1 on:
June 05, 2017, 09:05:27 pm »
A view of the inside.
The unknown device is circled in white. It was screwed on the heatsink of the power transitors.
Logged
anachrocomputer
Regular Contributor
Country:
Reply #2 on:
June 05, 2017, 09:12:50 pm »
Yes, it's a thermal cut-out. It opens the circuit at the marked temperature (75 deg C). If it's working properly, the two terminals should be a short circuit. When it gets too hot, the switch opens. The switch is rated for 220V, 1Amp.
Logged
JacquesBBB
Country:
Reply #3 on:
June 05, 2017, 09:18:23 pm »
Thanks,
Obviously, it is not working, as it is open at room temperature ( 20 °C).
My problem is that I do not have the schematics and one of the wires of hte sensor was cut.
I do not see very well where it should go.
below is the main board. The sensor is connected on one side on 29 ( lower left) which goes then on
the + of V4 (top left).
Last Edit: June 05, 2017, 09:20:40 pm by JacquesBBB
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
