Author Topic: Repair a DPS5005 PSU  (Read 434 times)
Offline kakasTopic starter
  • Country: hu
« on: October 02, 2021, 12:09:46 pm »
I switched on my unit with a load on the output. Input voltage was 50V, output set to 5V, load was appr. 3 amps.
 I do not know what went wrong, but the U1 with 6 pins marked in the picture burned. Since then it always outputs the input voltage.
Can someone tell me the ID of this component?  Thank you.
