Author Topic: Heidenhain Nd710 powers supply section repair  (Read 1441 times)
Offline Pat P.Topic starter
« on: August 12, 2020, 12:17:15 pm »
I have a Heidenhain Nd710 that seems to have a blown power supply section. Been trying to trace the fault basically at the component level, but no luck!
The only voltage I am showing at the connector to the main board is 30v (which I am assuming is for the VFD). A good portion of the board is covered with silicone, so it's proved to be a little tricky. Is there any chance anyone has a schematic for this?
Re: Heidenhain Nd710 powers supply section repair
« Reply #1 on: August 12, 2020, 08:39:53 pm »
Actual power supply is a YCL NAD-16c.
Looks like might be a faulty smps controller chip KA3842A - Vref output on pin 8 is showing less than 1 volt, should be 5V.
I'll order one up and see if that fixes it.
Offline MadTux
« Reply #2 on: August 12, 2020, 09:00:43 pm »
Fixed a Heidenhain Positip 850 with bad PSU some time ago, there the SMPS startup resistors were fried, so the chip didn't get the power for initial startup.
« Reply #3 on: August 13, 2020, 12:57:34 am »
checked all of those, were fine. I think it may have been a power surge that took the IC out, I'll order a couple at $.40 each just in case.
« Reply #4 on: August 18, 2020, 07:50:48 pm »
Turned out all was due to a bad electrolytic cap. marked 82 uf, tested at 60uf and 37ohm esr. substituted 100uf and good to go!
