Greetings
A fluke 79 III that show -OL- on Vdc and mVdc and won't measure resistance all without probes using a new battery
Vac show (0.00) normal and Buzzer , Diode mode works
Attached photos for the DMM
I dont know to what to check next
Any suggestions?
One possibility is that ohms voltage source is on all the time.
You should be able to check that.
