i destroyed a main primary cap of a switch mode power supply by drilling through the housing - so i have to replace it.
There are two of them (680uF / 200V), they are in series on 230V setting (there is a switch to switch 230V/115V)
I need the repair quickly, so do I have to replace it with the same capacity? I have one with 1000uF/200V here.
If they need to be the same value, I have two identical 250V/470uF out of another supply. Tue the lower capacity, there will be a power loss on the supply output maybe (that doesn't matter for my application).
Thanks for your answers
