It was blowing fuses.
Put the meter to it and the center pin of these "Mosfets"? are shorted to each other, which is the AC line... which would blow fuses obviously.
Looking around I can't really find the datasheet on that A69104 but looking at the rest of the circuit to see if it is something else (because both of them are shorted from center leg to left leg) I find that the MOV is shorted as well. This is going between the two center pins which would explain why they are shorted. Maybe the left and center should test shorted on that A69104?
I know these aren't the best pictures but it's what I got right now.
