Hello everyone,
New to the forum. I recently bought a faulty xbox one s and trying to track the fault and got stuck a little bit.
Xbox powers on and then immediately powers off. I figured that main processor is not getting power. Checked MOSFETS, no short circuits. But found something odd in Mosfet control circuit.
In all repair videos they check voltage drop (diode mode) between low side mosfet gate and source which are likely to fail. Normal readings are 0.6V with negative on gate and 1.9V with positive on gate. Video with timecode as an example:
https://youtu.be/HEceb1Qxyec?t=5m40sOn my console I am getting 1.1V (1.1kOmh) with negative on gate and 38kOmh with positive on gate, which is much higher than it supposed to be. I am having issues trying to figure out where these values are coming from. Definitely not mosfet, as I got confirmation that values stay the same even with mosfet completely removed. I suspect maybe mosfet controller, but don't want to start removing parts randomly. Found datasheet for same/similar mosfet controller. Pinout did match and also internal resistance values between gate output and SW/GND pins.
Extra information that might help. It is 3 lines buck converter (1 powers CPU and 2 power GPU). Readings are the same on all 3 lines. Each line has its own mosfet controller and all 3 mosfet controllers are controlled by larger NCP4205 chip. I found datasheet for NCP4200 chip, which is similar, however pinout does not match the board. However, Mosfet side of circuit seems to be very similar as on the board itself.
Circuit diagram:
Tried to do the same test on other power mosfets on the board. There is one more buck converter powering CPU northbridge. Values read out fine on it, even though circuit is not the same (same mosfets, but different controller).
Photo of area that I am talking about:
https://photos.app.goo.gl/Z6boeB8P3X3VmKnR9Any help is greatly appreciated. Not sure if such gate-source readings are unique to this xbox or other buck converters are similar, but it would be great to have any insights before I start removing components randomly trying to figure it out.
