Looking for one, &| a service manual. Note that this is
not the Tektronix 485, but the Tektronix
TAS 485. I already made that mistake.
I did find a service manual for a TAS 465 on the TekWiki, perhaps it is close enough to be useful? (100 MHz 2 channel vs my 200 MHz 4 channel, otherwise the grainy monochrome scan seems like a visual match)
On a side note, I have instrumentation for only a rudimentary calibration, so I greatly fear losing the current cal data, if it's even there still. Are there any gotchas that I might be able to avoid? Symptoms are failure to boot, no activity on the screen or in response to stimulus—including tube brightness, etc. All LEDs are lit solid. When I switch it off, there is a flash of the beam on the centerish of the tube, similar to the turn-off of an old TV, so I'm hopeful the HV is intact.
