Author Topic: Help Finding Battery Connection Pins on Schematic  (Read 5534 times)
Offline canadaboy25Topic starter
« on: December 31, 2015, 05:46:36 pm »
Hey guys, I am attempting to bring back my Toshiba A205 laptop that I foolishly killed.
I have a thread here https://www.eevblog.com/forum/repair/battery-connector-shorted-on-laptop/ which explains exactly what I did to it.  Long story short, I shorted two of the pins on the battery connector together and now the laptop will not stay powered up.
The reason I am making a new thread is because I am having some issues understanding this schematic.  I am used to reading Panasonic schematics for plasma repair and this one seems to be laid out in a different way.
All I am trying to find at this point, is where all of the pins on the battery connector are in the schematic.  Do I just need to search through the whole thing and look for pins which have a name that would suggest that they connect to the battery or is there something that I am missing on the schematic itself?  The laptop has 9 pins but some of them may just be electrically connected for increased current handling.
Thanks a bunch in advance.
canadaboy25
- Sometimes the light at the end of a tunnel is an on-coming train
Offline jdraughn
Re: Help Finding Battery Connection Pins on Schematic
« Reply #1 on: December 31, 2015, 09:16:54 pm »
They are right there on page 5 super obvious.
« Reply #2 on: December 31, 2015, 09:41:59 pm »
So what you're saying is the battery module only has 3 connections the the motherboard?  One of those connections is to the wall plug adapter.
canadaboy25
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #3 on: December 31, 2015, 11:47:58 pm »
This...
Don't ask a question if you aren't willing to listen to the answer.
Offline reagle
    • KuzyaTech
« Reply #4 on: January 02, 2016, 05:32:53 am »
Any idea which pins on CONN500 you shorted?
Not much on that interface should lead to the symptoms you describe- it at least should stay up when AC powered.
Offline SL4P
« Reply #5 on: January 02, 2016, 07:21:21 am »
BATT+ to BAT_ID would do the trick.
I'll put money on the EC being half fried.
What exactly do you mean by "do the trick?"  Am I supposed to short these pins to get it to work or is that what would have shorted the chip?
Also, what chip is the EC that you are referring to?
Shorting pins again isn't going to fix anything..
The EC is the Embedded Controller, what Apple would call an SMC. The various data connections from the battery run there, and it will not be even remotely tolerant of being shorted to BATT+. And it's one of the parts which can just turn the laptop off by itself.
Please be positive of which schematic applies to your laptop.
As mentioned in other posts from the other thread - at first guess from the supplied schematic), I'd be guessing that you shorted pins 2 & 3.  The zener might save you (depends on the breakdown voltage).
No other adjacent pin numbers look like they'd do anything permanent - unless the pin numbers are staggered somehow.
The bad news is that Pin 3 - BAT_ID goes directly into U22 (Winbond LQFP 128 pkg)
Which ;ools like a general mainboard controller for all non CPU requirements.
It doesn't bode well for a quick fix unless Santa was smiling on you.  Check the zener diode, or replace it - you might get REALLY lucky...!
« Last Edit: January 02, 2016, 07:26:33 am by SL4P »
« Reply #6 on: January 02, 2016, 04:49:24 pm »
I was thinking that it may have been the bat_id pin that got shorted.
The main concern I have is that the board is still actually working.  I can boot into the BIOS and Linux will start to boot.  All functions seem normal except the fact that it shuts itself down right away.  Would there be any way that I can override the signal that is shutting down the laptop jut to see if it will continue to run?
canadaboy25
« Reply #7 on: January 02, 2016, 09:00:49 pm »
I'm not sure what pin on this chip could even control a shutdown for the whole laptop.  The kill_swch pin is just for the wi-fi on off switch.
canadaboy25
« Reply #8 on: January 02, 2016, 09:24:01 pm »
If it does end up that the Ec is fried I'm not out of luck yet because they are literally dirt cheap ---> http://www.ebay.com/itm/Brand-New-WINBOND-WPC8763LDG-WPC8763-LDG-Chipset-graphic-IC-chip-/180815951085
canadaboy25
Online amyk
« Reply #9 on: January 03, 2016, 12:46:15 am »
EC_PW_ON.
You should check ACPRES signal, that indicates AC adapter is plugged in. The EC may not be seeing a signal from the battery nor ACPRES, so it shuts down after a timeout.
I haven't been able to find the full datasheet for the EC but many of them contain their own embedded ROM, and the ones you can buy are likely blank, so you'll have to figure out how to reprogram one.
Offline G7PSK
  • It is hot until proved not.
« Reply #10 on: January 03, 2016, 05:35:16 pm »
Out of interest have tried to run the laptop without the battery installed, the fault might be with the battery board only.
« Reply #11 on: January 05, 2016, 06:11:33 am »
EC_PW_ON.
I will be sure to check that.  I had a sneaky suspicion that there was more to replacing the EC than just re-soldering a new one in.  So I'm guessing that theres no way to get the files needed to reprogram it
Yes, I have been testing the laptop without the battery because the battery doesn't work at all.  I know for certain that the laptop works without the battery because I have used it like this lots before.
canadaboy25
