Author Topic: Repair of a Rohde & Schwarz power supply  (Read 1447 times)
Offline Supsnoopy66Topic starter
« on: August 16, 2020, 02:26:22 pm »
Hi all!
I got myself a used Rohde Schwarz FSEA.
The unit shuts down after 5 seconds indicating a PSU issue. I manage to force a startup but it appears that the 5.5V supply is only at around 2.5V. I tried removing modules but it doesn’t change.
I therefore suspect that the psu is the culprit here.
I was wondering:
- Does anyone happen to have a schematic for the Ascom psu used by R&S in that generation of instruments? It’s quite packed in there but nothing obviously wrong at first glance
- Did anyone face a similar issue? I found an evidence of a bad smd cap on the forum but mines seem ok so far.
Thanks a lot for your help!
Best,
« Last Edit: November 07, 2020, 10:17:08 pm by Supsnoopy66 »
Offline fzabkar
Re: Repair of a Rohde & Schwarz FSEA20 - power supply with pictures
« Reply #1 on: August 17, 2020, 12:55:10 am »
I would spend the time to draw up a diagram for the "mid board".
https://www.onsemi.com/pub/Collateral/UC3844-D.PDF
The following users thanked this post: Supsnoopy66
