Author Topic: Help finding correct LDO  (Read 841 times)
Offline firstcolleTopic starter
« on: February 02, 2019, 02:26:38 pm »
I repairing a board without the schematic. the problem is an LDO but I can't identify it.
what I know for sure:
3.3V out (it's used to power up a reverb microprocessor that works at 3.3V)
>12V input
the package is like a SOT223 but smaller (body 4mm x 2mm  SOT89??) and the pinout is:
1- Vout
2- gnd
3- vin
tab gnd
I can read only BA mark on top, the rest is blown up
can someone help me?
thanks
« Last Edit: February 02, 2019, 02:43:08 pm by firstcolle »
Offline eb4fbz
Re: Help finding correct LDO
« Reply #1 on: February 02, 2019, 03:06:20 pm »
There are a lot of linear regulators that could meet the specs. At 12V IN -> 3.3V OUT it doesn't have to be a LDO. For example L78L33ABUTR
The following users thanked this post: wraper
Offline wraper
  • Country: lv
« Reply #2 on: February 02, 2019, 03:45:57 pm »
If you had attached a photo, it's likely that other people would easily recognize it.
Online Doctorandus_P
« Reply #3 on: February 03, 2019, 12:37:17 pm »
Here is a list of SMD codes with BA:
https://alltransistors.com/smd-search.php?search=BA
