Author Topic: Help finding replacement 2pin DC rectangular notched plug  (Read 1185 times)
Offline mdronicTopic starter
« on: April 16, 2021, 09:48:40 am »
I don't seem to be able to find a replacement 2pin DC rectangular notched plug  for a switch mode 12v 5a. This is for a 12v thermoelectric cooler/warmer running on 240v. Several people seem to be trying to find them as well without success. I can find plenty of leads with the plug but don't want to have to pay for whole lead to cut up for plug. They seem to also be called "car cooler plugs". Image of switch mode, lead with plug, and reference socket museums. Any help greatly appreciated.
Offline coromonadalix
Re: Help finding replacement 2pin DC rectangular notched plug
« Reply #1 on: April 16, 2021, 02:33:08 pm »
you have thoses with rounded edges with a notch who can connect in the rectangular plug ???
something like IEC 320 C8  or   https://www.gamestop.com/electronics/accessories/cables-interconnects/products/2-pin-connector-ac-power-cord-6-ft/11099675.html
I think it's called the C7 connector, for the two rounded sides
I know there is a model with one square side too, used a lot in the Sony stuff,   i did had in the past an electrical item with your needed plug,   searched tons of vintage ac connectors, nothing came up like yours
« Last Edit: April 17, 2021, 01:44:48 am by coromonadalix »
« Reply #2 on: April 17, 2021, 01:41:14 am »
or this one ??
https://www.etsy.com/au/listing/622977541/vintage-power-cord-for-salton-hotray
Use a dremel to carve the needed notch ??
« Reply #3 on: April 17, 2021, 01:49:50 am »
Maybe this one on Ebay
https://www.ebay.ca/itm/Vintage-Tandy-AC-Power-Cord-2-Prong-With-Notch-Non-Polarized/224179246975?hash=item34321fd77f:g:LCAAAOSwZmpfd9jA
Seems the right one ??   just mod it with an 12vdc car plug on the other end ??
Offline AlexanderB
« Reply #4 on: April 19, 2021, 12:58:42 pm »
https://aliexpress.com/item/33035313469.html
Random/first result on Ali.
Vintage? Nah, just the power plug that literally all the mini TEC fridges use.
