A while ago, we had a bit of a power surge which caused the ice maker in our fridge to die. I've traced it back to the controller board in the ice maker which has a blown mov as well as the trace from the hot line to the primary side of the transformer/mov. I believe the transformer is fine, because I can read ~50 ohms across the primary, which leads me to believe that the mov and damaged track on the board are the only damaged parts. Could anyone help he find a suitable replacement mov for this board? I know very little about these, and don't want to accidentally put in the wrong part.
Some info on the blown mov:
SVR
14D 271KU
SEC C
And there is a silkscreen label beside it that says 650N/651N
I've tried searching for these, but can't really find anything, and don't really know much about these devices anyway.
I'll also attach some photos of the board.
Also, I live in Canada, the mains here is 120V.
Thanks in advance.
