Hello! i have this same amp. Produces distortion at low volume but not at high volume.
With headphones it sounds great but as soon as you connect an 8 ohm load, it distorts in the channel where it is, including headphones.
I changed the four main transistors and nothing ... they usually get 0.4V instead of 0.7V that they should be, so the problem will be with the power supply. I have also changed almost all the capacitors and it remains the same ...
Any clues ??, does anyone have the service manual ??
I'm going crazy without him ...
Thanks!!
