There is still though one unit (boot freeze problem) left to fix. I have found this blog http://41j.com/blog/2016/08/hacking-around-with-a-sdg800-sdg805/ and discovered that he is also a forum member at EEVblog forum. I have already Pm him asking for advice so maybe with his help I can get this unit to boot so I can update its firmware to the latest. Finger crossed ^^.
About boot freeze unit.
If boot stop to phase when it just show Siglent logo ok and after then boot up process do not go forward, it is possible to try recover using Siglent official method aka SD card recovery for SDG800. Least it need try before any other methods (other methods may in worst case destroy this possibility).
It need some tiny hardware rework, load system recovery FW file from SD card (SD card slot is there on main board) and after then return hardware back to original state and after it works ok then update to latest FW normal way.
As far as I know this method instructions and system recovery files are not in public share but they are available. This method is bit critical and need do carefully and exactly as instructions show without any single exception including also order of actions and including given tool for formatting SD card. I recommend you try this Siglent official SD recovery method, instead of some wild experiments that are presented here and there.
You can get instructions and recovery files package (.ZIP) from Siglent technical support but it need understand and promise they are confidential.
If you have troubles to get this, don't give up, I believe there are other ways to get it. Only if this method fails, then you can use some other things and experiments you may find around.
