Author Topic: Help fixing strange NEC CRT TV noise  (Read 723 times)
Offline OriginalDanTopic starter
« on: January 11, 2023, 07:30:56 am »
hi I've got a NEC ST-2602 CRT from 1986 the last few boot ups is giving a really odd sound thats rapidly getting louder with each brief use, its not the usual 15khz whine nor is it arcing, i couldn't find any schematics for this model the only somewhat similar schematics is for 120v cm-1991a/2591a but that version appears to have a different board layout. and mine is 240v
just a warning the mp3s have 15khz whine and i had to normalize boost the volume as the phone didnt pick it up well but its quite audible in real life
noise1.mp3 is what ive recently heard, noise2.mp3 the sound changes if i adjust the vhold dial
first assumption is a dying cap or two on the vertical line somewhere but i took off the back cover off:
album of the inside with higher res images
just a quick inspection the boards have majority rubycon capacitors that all appear fine, img06 img07 img08 around the flyback transformer is dirty but nothing stands out to me,
the anode cap image24 looks worn but that might just be dirty, I'm not sure where'd id find a replacement anode wire and cap as the rest of my crts are much smaller 14"17" not 26"
the neck board transistor legs image17all have similar gunk on the legs, they might be worth replacing? although the 'NEC C1506 L4YS' seem rare at roughly $52AUD for 2x of them
https://datasheetspdf.com/pdf-file/785150/NEC/2SC1506/1 unsure if there's a modern equivalant
so I'm kinda stumped, I'm gonna wait atleast a day before i discharge the anode and remove the chassis board for better images
i was going to gift this to a friend who wanted it for retro consoles but it really sounds like whatever part/parts are making that noise more and more is gonna die very soon, so id hope we can find the cause for preventive maintenance before something goes pop as parts like the flyback are impossible to find now
recalled a louis rossmann video mentioning to not straight away clean a board as it might erase clues leading to the issue so i might hold off on that for now but it certainly needs a clean, maybe some of those transistors replaced but for over $100 it doesn't seem worth it, a full recap seems excessive given they're not nonames
any suggestions?
« Last Edit: January 11, 2023, 08:21:58 am by OriginalDan »
Online inse
Re: Help fixing strange NEC CRT TV noise
« Reply #1 on: January 11, 2023, 09:44:52 am »
1st of all: clean the chassis with either a brush and a vac or compressed air.
Check the solder joints at the FBT.
The noise might come from a loose ferrite core, you can carefully poke around with an isolated tool (chopstick) in the running set trying to locate the culprit.
Include also the deflection coils.
I have never seen a worn out anode cap, if there was an isolation problem you would have noticed discharges.
Except from the noise, the set works fine?
Transistors don’t emanate noise.
« Last Edit: January 11, 2023, 10:23:55 am by inse »
The following users thanked this post: OriginalDan
« Reply #2 on: January 13, 2023, 03:55:43 pm »
thanks, i left it for 2 days. no pop or anything on the discharge, hosed the mainboard down and again with demineralised water, then scrubed with 99% iso, it did have white film forming on it i assume is leftover from the tap water or factory flux but a few rounds with iso seemed to get it ( don't have after pics due to iphones being the worst thing imaginable)
stupidly right at the end i forgot to plug the anode back in and booted it up to some screeching, turned off and redid the discharge on the anode plugged it in and thankfully i didn't fry myself or anything else
it's an improvement i can still slightly hear it but only with no input static, when i had a vhs playing via the composite bnc input i couldn't hear the noise anymore, when i can hear it, it's a lot more quiet
so hopefully for now the problems solved, poking around with a plastic tool when the noise was notible didn't seem to have any effect so I'm not sure. best wild guess is some parts near the flyback might be on their way out judging by the heat discolouration on a few components?
was hoping itad be possible to RGB mod but with no OSD i don't think it's possible. the two primary ICs are UPC1365C-NEC which has rgb output but no input, although there is a luminance input so it Might be possible for an svideo mod?
the other IC is UPC1377C  looks like id grab sync from that chip if svideo was possible, i don't quite know enough yet and without schematics I'm likely to kill something lol.
also i lost a fair amount of images transferring from an iphone to windows because i moved images instead of copying, cancelled after the first two and somehow lost half the images, never had that happen on any android phone T_T
« Last Edit: January 13, 2023, 03:58:17 pm by OriginalDan »
Online inse
« Reply #3 on: January 13, 2023, 05:18:29 pm »
I had this white residue also after cleaning PCBs, I assume this is undissolved ingredients from the flux and should not be an issue.
