Author Topic: Help ID'ing resistor type  (Read 1537 times)
Offline cozzaTopic starter
« on: April 29, 2015, 11:25:08 pm »
Hi all. I am repairing a lighting ballast, and I need to replace a couple of snubber resistors which are out of spec..
Does anyone recognise this type of resistor? The value is 10 ohm, 2W, and the service manual has no further information than this.
I need to know whether it is a non inductive carbon type resistor, or just an encapsulated mini wirewound type. If all else fails I'll cut one open and find out. Thought I'd ask first :)
« Last Edit: April 29, 2015, 11:27:12 pm by cozza »
Re: Help ID'ing resistor type
« Reply #1 on: April 30, 2015, 01:38:49 am »
So you've lifted a leg and measured it?
Looks like a standard old carbon resistor, for a snubber I don't think the type will matter much.
I you think it's loading might have caused it to drift, up it to a 5W.
Offline ludzinc
    • My Misadventures In Engineering
« Reply #2 on: April 30, 2015, 02:10:12 am »
In my experience, metal film resistors don't work well in snubber circuits.
The film develops a weak spot and the parts fail from there.  Use a carbon composite.
« Reply #3 on: April 30, 2015, 03:25:37 am »
There are two in parallel, out of circuit they measure 12.4 and 13.4 ohms on my digital LCR meter.
I cracked one open and it appears to be a carbon type, with a very thick outer encapsulation. A search of the usual parts places (RS and element14) turns up nothing physically similar.
