Author Topic: Help identify a tantalum capacitor  (Read 1484 times)
Offline Mikey5791Topic starter
  • Country: my
« on: May 19, 2020, 01:23:10 am »
Greetings to all. I am newly registered and hope to find some kind advice here.
Fyi, i am repairing an overheated Acer Aspire 4738 laptop which causes os to hang. Had changed a new cpu fan and thermal paste but it still hang after about 5 minutes running.
So i am proceeding to check on the back portion of the cpu and noticed three smd tantalum capacitor. It has marking of 330 on first row and 08D1Y. Sorry i am unable to get any schematic or parts list from google.   Can these be 330uF caps? But what voltage are those...2.5v or 6.3v or ??? I had checked esr is about 17Ω which i think is a bit high. No wonder the cpu is super hot.
Thanking in advance for anyone who can give advice and help where necessary. :)
Offline Whales
    • Halestrom
Re: Help identify a tantalum capacitor
« Reply #1 on: May 19, 2020, 03:18:43 am »
I would recommend less invasive tests before going as far as removing caps.  Memtest would be a good start.  Any reason you think the caps are bad, or are you stabbing in the dark?
Easiest way to find the voltage rating is to measure the voltage across them whilst the computer is running and work from there.  Ones directly under a CPU are likely to be extremely low voltage (ie 1.5V and below), other chips will vary.
Offline aqibi2000
« Reply #2 on: May 19, 2020, 10:41:13 am »
Really common issue
They are 330uF capacitors, if you search Toshiba laptops you’ll see the same caps problem
Tinkerer’
Offline fzabkar
« Last Edit: May 20, 2020, 09:19:54 am by fzabkar »
Offline m3vuv
« Reply #4 on: May 20, 2020, 10:50:10 am »
Ive a dell insiron that started doing the same,said cpu temp to high and shut down,normaly in under 60 seconds,i replaced the heatsink + fan from a spare machine,still the same,a few months before this i replaced the cpu with a 2.5 ghz from a 1.6  model,long story short the cpu was faulty,replaced it and bingo
  • Country: my
« Reply #5 on: May 21, 2020, 05:02:42 am »
Done the memtest much earlier and it passed and i also swap the memory card to use on another laptop. The memory is good.
I will go ahead with ordering and replacing all
the 330uF caps and see if the os freeze. The online order might take up to a month during this lockdown period. If it still the same, i will try replacing the cpu. If all is well, i will report back the good news.
My sincere thanks to all of you who help contributing many solutions in a clear way.
Much appreciated. :clap:
  • Country: my
« Reply #6 on: June 07, 2020, 04:10:09 am »
Received the 330 caps yesterday and replaced all the old caps with new ones.
The system boots to bios and Windows 7 for less than a minute, then the screen blacks out.
Power led and fan still running.
Shuts down power and restart. Now the os doesn't boot. Just black screen.
Offline james_s
« Reply #7 on: June 07, 2020, 04:17:12 am »
Is the CPU a soldered BGA? If so then I'd expect bad soldering, it's a very common problem with laptops, the Xbox 360 was notorious for it too.
