Author Topic: what thing/material to prevent solder go over neighbor  (Read 960 times)
Offline abdulbadiiTopic starter
« on: December 08, 2021, 05:41:32 pm »
How to solder tiny, tight, narrow pinhole and PCB layout, what thing/material to prevent solder to go over neighboring pin/hole ?
Of course, means it must be little/non heat conductive to prevent draining soldering iron heat
« Last Edit: December 09, 2021, 12:08:54 am by abdulbadii »
Online coromonadalix
Re: what thing/material to prevent solder go over neighbor
« Reply #1 on: December 09, 2021, 02:43:30 am »
you could use Kapton tape or what we call  "peel off"  its made for electronics, its a kind of semi liquid foam  (heat resistant solder resistant)  you mask the things you dont want to be touched .... it will dry in 15-30 mins, do the job you want to do   and after you can peel it off
you have some who can be washed off  ... it will desintegrate with water
The following users thanked this post: abdulbadii
