Author Topic: Help, identify chip D05A SOT23-6  (Read 619 times)
Offline daisizhouTopic starter
  • Country: cn
« on: September 17, 2024, 07:44:57 am »
Hallo everyone
This is a NEC LCD monitor.After it lights up, it always rolls up and down, it looks like the voltage is unstable.So I tried to replace the capacitor, but I didn't know the specific specifications of the SMD capacitor, so I disassembled the SMD capacitor.The dimensions of the capacitor are 1.6mm x 1.6mm x 3.2mm。
I don't know the withstand voltage and capacity of the chip capacitor,A friend suggested that I look for the surrounding circuit components. I took a picture and found a chip with a SOT23-6 package and the code is D05A.
It looks like a DCDC voltage conversion circuit.
If you know the exact model, please tell me, thanks.
daisizhou#sina.com #=@
Online fzabkar
Re: Help, identify chip D05A SOT23-6
« Reply #1 on: September 17, 2024, 07:57:43 am »
Qxxx are transistors.
  • Country: cn
« Reply #2 on: September 17, 2024, 08:17:04 am »
Is it a P-channel MOS tube?
Online fzabkar
« Reply #3 on: September 17, 2024, 08:40:38 am »
Examine the datasheet for the PWM controller IC.
  • Country: cn
« Reply #4 on: September 17, 2024, 12:19:02 pm »
It seems that the PWM chip should be this one
I found the manual for this monitor, but there is no schematic diagram available
Online fzabkar
« Reply #5 on: September 17, 2024, 07:27:00 pm »
I can't find any information on either IC. I believe D05A is indeed a MOSFET, with the same pinout that you have identified, but I don't know whether it is P-channel.
  • Country: cn
« Reply #6 on: September 17, 2024, 07:42:26 pm »
A105 1306 TSSOP8 This chip can't find any information
Offline gamalot
  • Correct my English
    • Youtube
« Reply #7 on: October 03, 2024, 03:54:40 pm »
D05A could be AO6400.
https://www.aosmd.com/sites/default/files/res/markings/AO6400.pdf
« Last Edit: October 03, 2024, 03:57:18 pm by gamalot »
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
The following users thanked this post: fzabkar
