Author Topic: Help Identify Chip Marked as DE-KOB (Vreg) & SiGE 5004L 430DV (5.8GHz Amplifier)  (Read 2555 times)
Offline MechatrommerTopic starter
  • Country: my
  • reassessing directives...
this circuit doesnt power up, or shorting out the PSU, so need repair. i'm guessing DE-KOB marked chip is a voltage regulator for 5.8GHz band FM transmitter RTC6705. and marked SiGE 5004L 430DV is the power amplifier... i need datasheet for both but cant find what chip are they, (i only got datasheet for RTC6705). please if you a familiar tell me what chips are those two? thanks.
Offline krish2487
Could not find anything on the SOT device.
Here you go for the SiGE 5004L
If god made us in his image,
and we are this stupid
then....
  • Country: my
thanks thats super 90% helpful as thats the damaged chip Vrail shorted to GND. the other voltage regulator still working 3.3V out.
