Author Topic: Datasheet for L6252  (Read 340 times)
Online Quarlo Klobrigney
  • Country: pt
  • Behind every alfoil hat is a genius
Datasheet for L6252
« on: June 11, 2019, 11:52:18 am »
Does anyone have a datasheet for an L6252, PLCC-44 package from ST?
All the usual suspects on the web have been tried. :( The exact P/N is L6252 ES4.
Voltage, does not flow, nor does it go.
Offline Chris56000
Re: Datasheet for L6252
« Reply #1 on: June 11, 2019, 07:13:59 pm »
Hi!
What's it used in?
I found a datasheet for the 44 pin L6256 which is an H.D.D. motor drive controller.
If it's any help you could trace round your L6252 and see if any of it's external components and connections match up with the L6256 – if your i.c. is from a h.d.d that's failed., then you might be able to get another h.d.d. with the same and swap 'em over!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
  • Country: pt
« Reply #2 on: June 11, 2019, 09:58:40 pm »
These are "loosies". No circuit board to reference to.
Offline amyk
« Reply #3 on: June 12, 2019, 03:27:01 am »
The L6254 is also a HDD IC, as is the L6250 and L6253 (http://www.shrubbery.net/~heas/willem/PDF/SGS-THOMSON/SGS/221.pdf -- where they are referred to as "3/5V Spindle Sensorless Driver" and "12V High Power Combo" -- no other references can be found on the Internet probably because these ICs are from the late 90s/early 00s...), so it's a pretty safe bet what the '52 is... but beyond "for HDD" nothing else can really be guessed.
  • Country: pt
« Reply #4 on: June 12, 2019, 10:50:59 am »
I appreciate the try, but for example, an L297 & L298 are 2 different animals, if you are looking for similarities in number only. Yes they are motor related, but as far as connections it's anyone's guess.
So I guess I am still looking for a datasheet......
I've been continuing a parts inventory and just wanted to qualify them before sticking them back as unidentified. :(
I can finally start to see a clear area of my workbench. A whole square 2 feet now!
Online CJay
  • M0UAW
« Reply #5 on: June 12, 2019, 11:49:17 am »
M0UAW
  • Country: pt
« Reply #6 on: June 12, 2019, 12:11:39 pm »
I'm afraid that's an L6262 you've linked to:
Online CJay
  • M0UAW
« Reply #7 on: June 12, 2019, 08:48:27 pm »
Ah, my bad, plus it's tqfp, not plcc but I think you'll find the 6252 on older WD drives
M0UAW
Offline fzabkar
« Reply #8 on: June 13, 2019, 04:53:06 am »
This chip was used in Western Digital's Caviar AC35100 and AC34000 models.
See pages 10 and 11:
https://www.acelab.ru/dep.pc/doc.pc3000dos/050530.001/PCA35100.pdf
